언어
3 MPPTs
200% oversizing
The MS Series is GoodWe’s answer to the residential segment's expanding needs. This 5-10 kW, single phase, 3 MPPTs inverter is a powerful and versatile solution. It is truly a champion in terms of DC oversizing, offering as much as 200%, way above the competition, making it possible as well to achieve 110% AC overloading. With a start-up voltage of only 80 V the MS is able to generate electricity earlier than equivalent products, achieving a high efficiency of 97.7%. This inverter is compatible with bifacial modules outstandingly and its maximum current input reaches 12.5 A per string. The MS comes with an AFCI integrated protection and the light weight allows for effortless installation.
Compatible with bi-facial modules
80V startup voltage
3 MPPTs
97.7% max. efficiency
3 MPPTs
200% oversizing
The startup voltage of MS series only requires 80 V. This considerably low startup voltage distinguishes from the competitors that the solar system can generate power from dawn to dusk and even in very weak sunshine or irradiation whether condition, harness as much solar energy as possible.
With 200% DC input oversizing and 110% AC output overloading capability, the MS series is driven to its full capacity by adding extra reflections from the backside of bifacial panels, to increase the power output under low solar radiation conditions.
200%
DC INPUT OVERSIZING
AC OUTPUT OVERLOADING
모델
GW5000-MS
최대 입력 전압(V)
MPPT당 최대 입력 전류(A)
12.5/12.5/12.5
MPPT당 최대 입력 전류(A)
1/1/1
정격 출력 전력(W)
5
정격 출력 전압(V)
220/230
모델
GW6000-MS
최대 입력 전압(V)
MPPT당 최대 입력 전류(A)
12.5/12.5/12.5
MPPT당 최대 입력 전류(A)
1/1/1
정격 출력 전력(W)
6
정격 출력 전압(V)
220/230
모델
GW7000-MS
최대 입력 전압(V)
MPPT당 최대 입력 전류(A)
12.5/12.5/12.5
MPPT당 최대 입력 전류(A)
1/1/1
정격 출력 전력(W)
7
정격 출력 전압(V)
220/230
모델
GW8500-MS
최대 입력 전압(V)
MPPT당 최대 입력 전류(A)
12.5/12.5/12.5
MPPT당 최대 입력 전류(A)
1/1/1
정격 출력 전력(W)
8.5
정격 출력 전압(V)
220/230
모델
GW10K-MS
최대 입력 전압(V)
MPPT당 최대 입력 전류(A)
12.5/12.5/12.5
MPPT당 최대 입력 전류(A)
1/1/1
정격 출력 전력(W)
10
정격 출력 전압(V)
220/230
뉴스레터
J반갑습니다.
