언어
A4-sized
5.8kg
The brand new XS model from GoodWe is an ultra-small residential solar inverter specifically designed to bring comfort and quiet operation as well as high efficiency to households. Its capacity ranges from 0.7 kW to 3.0 kW and its most outstanding characteristic is light weight, which is only 5.8 kg and as well as its extremely compact size equivalent to an A4 paper, that make it particularly easy to carry & install.Remarkably, it offers a 130% of DC input oversizing and it's able to achieve a maximum European efficiency of 97.2%. Conveniently, the communication options available on this inverter are both LAN and Wi-Fi.
A4 size
Light weight
130% DC oversizing
97.6% Max.efficiency
110% AC overloading
40V start-up voltage
A4-sized
5.8kg
Compressing 3 kW DC/AC transforming technology into an A4 size inverter is unbelievable. However, GoodWe did it! Weighing less than 6 kg, inverters can be easily installed! Additionally, it also significantly reduces shipment and stock cost.
An optional LAN/Wi-Fi communication offers customers different monitoring methods to cater for different needs. Customers are able to choose the most convenient way to monitor their solar systems. It also allows the customer to switch into another monitoring method after installation. GoodWe cares about your feelings and experiences.
Even though the XS Series is extremely compact and tiny, it doesn’t mean standard features are sacrificed.
The XS is still equipped with 130% DC oversizing capability which allows full load output during extreme weather conditions and what’s more, its European efficiency can reach 97%, which is even more compared to its predecessors.
97.2%
EUROPEAN EFFICIENCY
모델
GW700-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
0.7
정격 출력 전압(V)
230
모델
GW1000-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
1
정격 출력 전압(V)
230
모델
GW1500-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
1.5
정격 출력 전압(V)
230
모델
GW2000-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
2
정격 출력 전압(V)
230
모델
GW2500-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
2.5
정격 출력 전압(V)
230
모델
GW3000-XS
최대 입력 전압(V)
500
MPPT당 최대 입력 전류(A)
12.5
MPPT당 최대 입력 전류(A)
1
정격 출력 전력(W)
3
정격 출력 전압(V)
230
뉴스레터
J반갑습니다.
