이 웹사이트는 쿠키를 사용합니다
이 쿠키들을 통해 당사에서는 귀하의 당사 웹사이트 방문 관련 정보를 수집합니다. 귀하의 개인 정보 존중은 당사 정책의 핵심입니다. 당사의 개인 정보 보호 및 쿠키 정책에 대한 상세 정보는 동봉된 내용에서 확인할 수 있습니다. 현재 진행하기 위해서, 당사에서는 귀하께 당사의 약정에 동의해 주실 것을 요청합니다. 협력해 주셔서 감사합니다.개인 정보 보호 및 쿠키 정책.
GoodWe SNS
youtobe@1x-759-329.svg youtobe@1xyuanse-825.svg
1.ins-175.svg 1.ins-180.svg
Xlogogrey-419.svg Xlogoblack-528.svg
2019-03-04
GoodWe 인버터, 스페인 GENERA 2019에서 주목
GoodWe debuted at the show with the display of its latest residential and C&I applications as well as its brand new three-phase energy storage solution, the ET Series hybrid inverter.
GoodWe inverter series have obtained the RD 1699 and UNE standard certifications for grid connected PV installations in Spain, including its best-selling DNS Series inverter and the Red Dot Design Award winner, hybrid-ready DSS Series. With a low start-up voltage of only 120V, a wide MPPT range and maximum efficiency of 97.8%, the DNS Series can provide high performance and greater options for any household system. The internationally awarded GoodWe DSS Series is compatible with bifacial double-glass modules. Furthermore, DC oversizing of up to 35% and AC overloading of 10% is allowed. Thanks to its reliable performance, the DSS Series can reach a highest efficiency of up to 98.6%.
On the C&I product portfolio, GoodWe presented the MT Series for large scale commercial rooftop and ground-mounted projects. Apart from offering a more compact design and competitive price, the MT Series provide a continuous power boost function to achieve a higher yield and quicker return on investment.Another star at GENERA was the innovative ET Series three-phase energy storage inverter which maximizes self-consumption. Covering a power range of 5 kW, 8 kW and 10 kW, the ET Series allows up to 100% overloading to maximize power output and features Uninterruptible Power Supply (UPS) to inductive loads such as air conditioners or refrigerators with an automatic switchover time of less than 10 milliseconds.
As Europe´s fifth largest economy, Spain plans to source 70% of its electricity from renewables by 2030 and 100% in 2050. GENERA was a perfect opportunity for GoodWe to showcase its innovative solutions which can contribute to meet these goals.
뉴스레터
J반갑습니다.
구드웨이 통신 구독
아래에 정보를 받기 위해 상세한 정보를 삽입하십시오
당신은 어떤 종류의 Goodwe 사용자입니까?...
소매점
유통 업체
최종 사용자
기타
인증번호 입력:*
나는 좋은 소식을 받아들였다 프라이버시 정책 나는 이 조건들을 받아들인다
가입
