이 웹사이트는 쿠키를 사용합니다
이 쿠키들을 통해 당사에서는 귀하의 당사 웹사이트 방문 관련 정보를 수집합니다. 귀하의 개인 정보 존중은 당사 정책의 핵심입니다. 당사의 개인 정보 보호 및 쿠키 정책에 대한 상세 정보는 동봉된 내용에서 확인할 수 있습니다. 현재 진행하기 위해서, 당사에서는 귀하께 당사의 약정에 동의해 주실 것을 요청합니다. 협력해 주셔서 감사합니다.개인 정보 보호 및 쿠키 정책.
GoodWe SNS
youtobe@1x-759-329.svg youtobe@1xyuanse-825.svg
1.ins-175.svg 1.ins-180.svg
Xlogogrey-419.svg Xlogoblack-528.svg
2020-02-17
GoodWe becomes the world’s first non-European inverter manufacturer to obtain the very demanding VDE-AR-N 4110-2018 compliance certificate.
To give some context: the VDE-AR-N 4110-2018 Technical Requirements for the connection and operation of customer installations to the medium voltage network constitute a set of diversified conditions put in place by the VDE Testing and Certification Institute that network operators, generating plant operators but also component manufacturers such as GoodWe need to meet in order to ensure the safe and stable connection of energy generating equipment such as our MT-Series inverter to the European electric grids.
The latest version of this set of technical requirements (Guideline FGW TG 4 Rev.9) derive in great measure from the European network codes and contain "expanded requirements for fault ride-through of short voltage drop as well as for providing reactive powers through decentralized power generating plants”.
The fact that the GoodWe has passed this set of requirements contributes in a very important way to certify that the GoodWe MT-Series is compliant with the European regulations and that the connection of the MT-Series inverter to the European grids is safe as it does not disrupt their stable performance.
GoodWe technically outperforms formidable competitors: praise to the company’s R & D capabilities
In these times of fierce market competition, this important achievement eloquently proves once again that GoodWe is a global inverter player to be reckoned with. The VDE-AR-N 4110-2018 technical requirement are one of the most demanding and exhaustive standards of the PV inverter industry. After months of dedication and a long-term collective effort, GoodWe has been the first non-European supplier to get this recognition and this feat clearly illustrates the very high technical capabilities and strengths that the company has reached over the years. Without a doubt, these capabilities are now among the strongest in the whole industry and encompass every element in the process of technological development of the company: a great R & D team, best design and top of the line components.
The doors of Europe are now open for the GoodWe MT-Series
The MT-Series is one of GoodWe’s most successful and globalized inverters. For the past two years, the number of deployments of this inverter across the world has multiplied, contributing to raise the reputation of this inverter, which is considered, thanks to its outstanding DC oversizing of 50% and full operation at extreme temperatures, one of the most cost-effective in the industry with the lowest LCOEs.
On the back of its enormous success in markets such as India, Turkey and Brazil and after being selected by a number of international EPCs, the GoodWe MT-Series landed last year in Europe with landmark projects in Hungary, where it was selected thanks to its remarkable functionality, which includes PLC Communications and string level monitoring.
After passing the VDE-AR-N 4110-2018 requirements and obtaining this certification, the GoodWe MT-Series is now officially recognized by the most authoritative technical body in the industry such as the TÜV Rheinland Industrie Service GmbH as a compliant utility grade inverter. This important success will contribute to open the doors of Europe (and the rest of the world) to the GoodWe MT-Series, allowing us to have a larger participation in the utility projects of the continent and as a consequence a stronger contribution to the energy transition of the region, expected to accelerate starting from this year onwards. This is thus a great milestone and a great news that gives again great pride.
뉴스레터
GoodWe Technologies Co., Ltd. 데이터 보호 선언
GOODWE Solar Academy 데이터 보호 선언
J반갑습니다.
구드웨이 통신 구독
아래에 정보를 받기 위해 상세한 정보를 삽입하십시오
당신은 어떤 종류의 Goodwe 사용자입니까?...
소매점
유통 업체
최종 사용자
기타
인증번호 입력:*
나는 좋은 소식을 받아들였다 프라이버시 정책 나는 이 조건들을 받아들인다
가입
