이 웹사이트는 쿠키를 사용합니다
이 쿠키들을 통해 당사에서는 귀하의 당사 웹사이트 방문 관련 정보를 수집합니다. 귀하의 개인 정보 존중은 당사 정책의 핵심입니다. 당사의 개인 정보 보호 및 쿠키 정책에 대한 상세 정보는 동봉된 내용에서 확인할 수 있습니다. 현재 진행하기 위해서, 당사에서는 귀하께 당사의 약정에 동의해 주실 것을 요청합니다. 협력해 주셔서 감사합니다.개인 정보 보호 및 쿠키 정책.
GoodWe SNS
youtobe@1x-759-329.svg youtobe@1xyuanse-825.svg
1.ins-175.svg 1.ins-180.svg
Xlogogrey-419.svg Xlogoblack-528.svg
2020-04-08
GoodWe is world’s first and only inverter brand compatible with BYD Battery-Box Premium HVM: four storage products now compatible
GoodWe Storage Solution
GoodWe has the most comprehensive storage portfolio in the industry, including European brands, covering single-phase, three-phase, high voltage and low voltage. GoodWe invests a lot on researching and developing storage solutions in different application scenarios and has massive potential in the storage sector. In markets where electricity prices are high such as Italy, an increasing number of residents prefer to install hybrid inverters due to FIT and high electricity bills, with the intention to maximize self-consumption. GoodWe’s backup function ensures steady 24-hour power supply in extreme weather conditions. While in countries where grids are unreliable or in poor condition, the Hybrid systems are the best alternative for self-sufficiency. The market is hungry for storage and GoodWe has the ingredients.
Name of Inverter: GoodWe ET Series, Three-phase Energy Storage Inverter, Dual-MPPT
Unique Selling Points:
  • Maximum efficiency up to 98.2%
  • Uninterruptible Power Supply
  • Wide battery voltage range
  • Fanless design, quiet operation
    Name of Inverter: GoodWe EH Series, Single-phase Energy Storage Inverter, Dual-MPPT
    • UPS automatic switch in 10ms
    • Wide battery voltage range 85~450V
    • Large loads when back-up
    • Maximize self-consumption
    • Pre-wired, plug & play
    Name of Inverter: GoodWe BT Series, Three Phase AC-Coupled Retrofit Inverter, 5-10kW
    • UPS function (uninterruptible power supply)
    • High voltage battery (180-600V)
    • 10% AC output overloading
    • Battery input reverse polarity protection
    Name of Inverter: GoodWe BH Series, AC-Coupled Retrofit Inverter, 3-6kW
    뉴스레터
    GoodWe Technologies Co., Ltd. 데이터 보호 선언
    GOODWE Solar Academy 데이터 보호 선언
    J반갑습니다.
    구드웨이 통신 구독
    아래에 정보를 받기 위해 상세한 정보를 삽입하십시오
    당신은 어떤 종류의 Goodwe 사용자입니까?...
    소매점
    유통 업체
    최종 사용자
    기타
    인증번호 입력:*
    나는 좋은 소식을 받아들였다 프라이버시 정책 나는 이 조건들을 받아들인다
    가입
