언어
Covering a power range of 5 kW, 8 kW and 10 kW, the ET Series allows 30% DC oversizing to fully maximize yield during extreme hot and cold weather and features a wide battery voltage range of 180 – 550 V to ensure customers flexibility choices and compatibility with different type of lithium battery. Furthermore, it features UPS function to inductive loads such as air conditioners or refrigerators with an automatic switchover time of less than 10 milliseconds. It is also equipped with AC charging function whereas alternative current is able to charge the battery even when the inverter has not met its maximum performance.
Compact and powerful ET series delivers independence and non-stop energy for both households and commercial applications!
For more product details and quotation requests, please visit our solution websitehttp://en.goodwe.com/Products/index_et.htmlor contact our sales team sales@goodwe.com
뉴스레터
J반갑습니다.
